code 2
Old Apr 29, 2005 | 02:31 PM
finalimpact's Avatar
Default RE: code 2
ORIGINAL: sacicons
on OBD1?
there is a possibility that i am smoking from the bong........
Old Apr 29, 2005 | 03:10 PM
neon3kgt's Avatar
Default RE: code 2
obd 1 cars only have one o2 sensor, and by law, 98 and later are obd2, the second 02 is used for the computer to check up on the cat to make sure that its working properly.the computer should be getting a steady .5 volts. to much higher or lower and the computer thinks the cat isnt working. and sence the 02 creates AC current, then im guessing those .5 volts you would have to send back are AC. the pre cat 02 sends "wagging" signals to the computer between 0 and 1v, so i dont think you can just wire them together. if you just disconect your 02, then your vehicle will go into open loop mode and usually that means it runs richer.
i think thats all right... please correct me if im wrong.
Old Apr 30, 2005 | 01:48 AM
Default RE: code 2
ive had b16A on my mind all week.......... from stated info above looks like you will be replacing primary o2
jdtrio
Mar 17, 2010 02:52 AM
ktownjeep
Jun 20, 2007 01:40 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
sneekapeek
Jun 28, 2004 09:31 PM
sirach38
Jun 19, 2004 10:35 PM
