Code problem
Old Aug 11, 2010 | 04:54 AM
Max62's Avatar
Unhappy Code problem
I have a 95 civic LX. I had a code 1,1,1 which I believed is o2 censor. I replaced it. Still showing the same code. When I do the code, red SRS light constant blink, engine light 1,1,1. I cleared code at fuse box at engine and also had to disconnect battery, because code will not reset. Normally you clear code and stay cleared until you drive it. Well I tried it again doing the code and it was still coding so I pull the fuse at box to see if it stop and it was still coding (blinking)(maybe I shouldn’t have done that but I blew a fuse)
Does the red SRS suppose to blink, when doing the code? Why will the code not clear prior of driving? What's the code trying to tell me?
Old Aug 11, 2010 | 05:20 AM
This section is for problems with the forum itself, not tech questions.
Moved to the tech section.
Old Aug 11, 2010 | 11:10 AM
Max62's Avatar
Thanks
Old Aug 11, 2010 | 12:21 PM
There's a different method for clearing SRS codes.
If you still have CEL code 1, then you need to check the O2 sensor wires for an open or short. A bad wire splice job is common cause.
jdtrio
Mar 17, 2010 02:52 AM
noops
Oct 19, 2007 02:08 PM
ktownjeep
Jun 20, 2007 01:40 PM
hans747
Feb 17, 2005 11:06 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
