Cold Start Problem
Old Sep 30, 2007 | 09:59 PM
bballdude's Avatar
Default Cold Start Problem
When the outside temperature is below 45º F or so, my car wont start. The engine turns but it acts like it's not getting any fuel. When it gets warm outside, it starts just fine. It has a new battery so thats not the problem.
It's a 1989 automatic Civic LX..
Old Oct 4, 2007 | 07:35 AM
steelergrl's Avatar
Default RE: Cold Start Problem
I have the same problem and have no idea what it is. We replaced the catalytic converter, the idle control valve and fuel related things, but no luck. I have a 2000 Honda Civic SI. Let me know if you get any good advise about this because I am at a loss..
Old Oct 4, 2007 | 07:40 AM
Could be the main relay, though usually those act up when hot. Any sort of intermittent crank but no start should make the main relay a suspect. At least on a '91, the check engine light will stay on when cranking if the main relay is not working, normally it will be off during cranking unless you crank for a very long time.
bcos
Nov 17, 2023 11:43 AM
qleffel
Jan 6, 2014 01:27 PM
reyrivera
Dec 10, 2011 12:49 PM
bcos
Jan 8, 2010 04:48 PM
thesteveman
Feb 10, 2005 01:07 AM
