Coolant Flush
Old May 4, 2007 | 04:51 PM
ryank327's Avatar
Default Coolant Flush
I plan on doing a coolant flsuh this weekend. I know its a simple process . But I was just wondering if someone could give me a brief explanation on hwo to do it so Im a little more confident. and no i dont have a haynes manual.
Old May 4, 2007 | 05:00 PM
windcalmer's Avatar
Default RE: Coolant Flush
O.K.
Take off radiator cap.
Unscrew drain plug((the white screw on the bottom of the radiator))
Let the fluid drain.
Tighten drain plug back up.
Pull upper radiator hose off of the radiator leaving it attached to the engine.
Take garden hose and start pumping water into the radiator.
Continue with the water into the radiator till it flows out of the upper radiator hose.
Reattach all hoses.
Refill Radiator with coolant as per manuf. instructions.
Done!!!
IF I LEFT ANYTHING OUT SOMEONE PLEASE CORRECT ME.
Good luck with it Ryan.
Old May 5, 2007 | 09:21 AM
The only thing I would add is, don't forget to bleed the system once you've finished the flush
Old May 5, 2007 | 10:23 AM
Fiirkan's Avatar
ORIGINAL: Forty04
Vapor lock FTL! deffinately bleed the system
Old May 5, 2007 | 12:39 PM
windcalmer's Avatar
DAMN!!! I knew I forgot something. Always, always. One little thing. LOL Oh well.
Old May 6, 2007 | 02:43 PM
ryank327's Avatar
I cant find the Bleed valve. Anyone know where it is in the B Series usually. I feel like Im blind cause ive done this on D-series plenty of times lol
Old May 6, 2007 | 03:09 PM
windcalmer's Avatar
I always just do it the cheap way and sqeeze the lower hose till I dont see anymore bubbles. LOL
Sorry I have a D. I am no help at all.
Old May 6, 2007 | 03:40 PM
ORIGINAL: ryank327
I think its by the t-stat... could be wrong though
Old May 6, 2007 | 04:25 PM
riceburner700's Avatar
get some BG flush bottle and poor it in with the water and run the car up to operating temp then drain and fill like normal
Old May 13, 2007 | 05:09 PM
Tim706's Avatar
When I do coolant flushes i also like to unhook a heater hose, two lines approx 1 inch in diameter running into the firewall, and flush water through that as well (in the same manner as you flushed out the radiator), the heater core, afterall, is just a mini-radiator.
Shaklee3
Dec 4, 2008 05:00 PM
macbeth18288
Sep 17, 2008 07:15 PM
ELLAS1945
Jul 12, 2007 11:13 AM
ELLAS1945
May 17, 2007 08:30 PM
amsmk
Jan 22, 2006 01:57 AM
