Coolant Help
Old Feb 27, 2008 | 05:29 AM
bbman400's Avatar
Default Coolant Help
Please help guys. I have an 05 civic and my radiator is transferring all of the coolant to the overflow tank. As a result the radiator empties and the overflow tank overflows and spews out of the top. Heater stopped working but Car does not overheat. I immediately took the care to the dealership and they flushed the system and rebleed it. They scanned the ecu and found no codes. Got home and the same problem occurred. What could it be???
Old Feb 27, 2008 | 05:54 AM
Default RE: Coolant Help
Right after the cooling system was flushed, did the heater work? If not, the thermostat may be stuck closed. Another possibility is that the radiator cap is faulty and unable to hold proper pressure. Alternatively, the worst case scenario is that the head gasket is blown and exhaust gas is being forced into the cooling system, causing the problem.
Old Feb 27, 2008 | 06:12 AM
bbman400's Avatar
Yes the heater worked because there was coolant in the radiator.
Old Feb 27, 2008 | 07:09 AM
Faulty cap, or a tiny air leak in the hose between the radiator and the "overflow" tank.
Especially look at the gasket in the top of the cap around the outside edge. Or just replace it regardless.
The system depends on a vacuum forming in the radiator and pulling the coolant back out of the tank as the engine cools. The flow is controlled by valves in the radiator cap.
Old Feb 27, 2008 | 05:55 PM
bbman400's Avatar
I'm not seeing any white smoke at all. What could cause a problem like a blown gasket?? How do I know for sure???
Old Feb 27, 2008 | 06:02 PM
Before you concern yourself with the head gasket, replace the radiator cap and look for a leak from the coolant reservoir hose.
Old Feb 27, 2008 | 06:21 PM
bbman400's Avatar
took it to honda twice... my own mechanic once. they pressure tested it looked for leaks, ran it.. and found nothing..no white smoke, no overheating. how could i know for sure waht it could be
Old Feb 27, 2008 | 06:28 PM
You may want to ask the dealership or a mechanic to do compression and leak down tests on the cylinders. Is there any oil in the coolant or coolant in the oil?
Old Feb 27, 2008 | 06:29 PM
bbman400's Avatar
i havent checked that yet, what exactly am i looking for?
paak
14
Nov 19, 2011 02:24 PM
s2000gtx
12
Apr 16, 2011 04:34 PM
vertech0
May 22, 2008 08:32 AM
dc4mn
Mar 2, 2008 11:21 PM
civicexracer
Feb 24, 2007 06:52 PM
