crank, no spark, no fuel, good fueses, good main relay
Old Jun 28, 2010 | 12:58 AM
edmaxx's Avatar
i have a volt meter, and when you say under the hod on the fuse box side you mean the driver side (right) looking at the front of the car?
Old Jun 28, 2010 | 12:59 AM
edmaxx's Avatar
oops sorry thought you said hood not dash, the fues looked good, can i volt it?
Old Jun 28, 2010 | 01:04 AM
fuses under the hood are on the passenger side in the black box by the batt.
test the 30 amp fuse under the dash that sits off by itself for power when the key is in the "on" position (dash lights should be on)
Old Jun 28, 2010 | 01:11 AM
edmaxx's Avatar
alright be right back
Old Jun 28, 2010 | 01:18 AM
edmaxx's Avatar
both my 30s have 12v
Old Jun 28, 2010 | 01:29 AM
does the dash lights come on when you turn key to on" position?
Old Jun 28, 2010 | 01:30 AM
edmaxx's Avatar
bump...?
Old Jun 28, 2010 | 01:31 AM
edmaxx's Avatar
ya they all come on? check engine is up too. but i removed that thirty so i lost my engine codes and cant check them
Old Jun 28, 2010 | 01:50 AM
edmaxx's Avatar
Old Jun 28, 2010 | 03:47 AM
Mecca8383's Avatar
Originally Posted by edmaxx
alright,1992 honda civic hatch, d15b8 p05 ecm. so i was working on wring a a fuel level gauge when i touched my + to my neg wire to my fuel pump. ive checked all i can think of, my fueses are all good and i got a new main relay, my wires are good, checked those, if i wire 12v to the fuel pump it runs but the car wont spark now? bad ecu?
Yeah just check everything in your dizzy..anything can go wrong in there to not have a spark. Also..do you hear the fuel pump come on the 2nd click when you turn the key?
i cant even find my map sensor i dont even know if i have one to be honest? please help!!
It should be right next to your fuel filter..on the right side when you're looking at the engine..it's the little small black box(about the size of a ring box).
