Crank shaft pulley
Old Nov 25, 2007 | 03:43 AM
Cosmo's Avatar
Default Crank shaft pulley
I have a 1995 Honda Civic VX D15Z1. I want to change the timing belt, but I cant't find a way to hold the crankshaft stationary so I can remove the belt pulley. I have a shop manual that says to remove the flywheel inspection cover and lodge a screwdriver in the flywheel. I can't find a flywheel inspection cover. Any help?[/align]
Old Nov 25, 2007 | 08:15 AM
Fiasco's Avatar
Default RE: Crank shaft pulley
The only tool ive ever needed to use to negotiate the crank pulley is a chain wrench. Works everytime.
Old Nov 25, 2007 | 01:29 PM
Cosmo's Avatar
OK. So put a chain wrench on the pulley?
Old Nov 25, 2007 | 02:30 PM
Mugan's Avatar
The flywheel plate is bottom by the oil pan.
The way I did it was use a rod between the lug bolt and put it in gear. Us blocks & jackstands.
SpeedRacer_87
15
Aug 12, 2007 09:23 PM
radco10
Jan 18, 2007 03:58 PM
Mario89
Nov 27, 2006 09:31 PM
boostnub
Nov 8, 2006 01:17 PM
skidbump
May 15, 2005 08:53 PM
