cranking but not starting
Old Mar 13, 2006 | 08:11 PM
SkeetFresh's Avatar
Default cranking but not starting
So i got this car when it was in a non-running condition. I ended up taking apart the engine and replacing the head, after this the car ran perfectly for awhile, then the radiator blew so i replaced that, the car then ran perfectly for a few more weeks and then i noticed some problems starting with starting my car. It would begin to need to crank more for it to acually start and then one day it just stopped starting. First I thought it may be low on gas, but that wasent the problem, next i replaced the disributor cap, then the coil, then the ICM. The fuel pump is working fine and i checked and plenty of gas is getting into the engine. When I use a timing gun and crank the engine i get very little to no spark in all 4 spark plugs. The plugs are fine and gapped correctly. I am pretty sure it must be an electrical problem, so if you have anything that may help me here...I would love the help..i jus want the car to run again!
lemon
Mar 18, 2013 07:48 PM
bmarsh1605
Dec 2, 2011 07:44 AM
IslandCivic808
Jul 30, 2009 03:10 PM
totenkopf
May 31, 2007 03:36 PM
acg72
Apr 28, 2007 03:35 PM
