Crazy Idle problem
Old Sep 23, 2005 | 05:46 PM
rchapa's Avatar
Default Crazy Idle problem
I am having a idle issue with a 98 civic dx, when I first start the car cold it is normal. Once it gets to a normal operating
temp it begins to rev up and then down. When I turn on the AC it stops and is normal again. I purchased a code reader and
found PO113 and PO505 as a trouble code. I ahve replaced the IAT sensor and is still having the same problem. The PO505 code
sugess the IAC valve system fault. Does anyone know where that valve is located on a 98 civic 1.6 ltr or have any other suggestions
that may solve the problem. This is only a idle issue once you accelerate it stops until you get to a stop
Old Sep 23, 2005 | 06:20 PM
fast93civic's Avatar
Default RE: Crazy Idle problem
i think it may be your throttle position censor TPS, my car does that if its in park or neuatral, i hit the gas rev up to like 6 k, then when the needle drops down it bounces between like 500-1200 rpms. So check that TPS.
tayglo
Dec 19, 2015 05:53 AM
TAT76
16
Dec 29, 2012 03:36 PM
03civex
15
Oct 28, 2008 08:20 PM
jm0597
Apr 25, 2008 10:26 AM
wds13196
Feb 27, 2007 05:13 PM
