cruise control diagnostics
Old Sep 28, 2012 | 06:46 AM
northwoods's Avatar
Default cruise control diagnostics
Gents:
Just picked up a 2000 ex 5 sp with a non-functioning cruise control. I will be going thru the system bit by bit, but I thought I would throw out a general question to those that have experience with this system - are there any areas that you would check first?
The inst cluster light does not come on. The vacuum lines look OK.
Thanks!
Old Sep 28, 2012 | 07:44 AM
If the light on the button comes on but the cruise won't engage and light the light on the dash, check the switches on the brake and clutch pedal. Common for the rubber pad on the pedal arm to fall out and then the button on the switch doesn't get pressed.
Old Oct 2, 2012 | 07:59 AM
northwoods's Avatar
thanks for the tip. Turned out to be pretty simple - st wheel button assy connector was disconnected. wish they were all this simple...
Old Oct 12, 2012 | 03:35 PM
PCollen's Avatar
How does THAT happen, unless someone was in there tampering, replacing air-bag, or did it on purpose ? It doesn't just work itself loose, does it ?
Streetsoldier4
Jun 27, 2010 10:54 PM
flem1959
Dec 4, 2008 01:28 PM
r69bp
Feb 26, 2008 02:03 AM
dmsteele92831
Jul 23, 2007 11:10 AM
streetheat
Feb 21, 2007 09:52 PM
