Cruise Control Help
Old Oct 21, 2008 | 12:43 PM
00Si_Bennett's Avatar
Default Cruise Control Help
Press the cruise control button to turn it on - check
Accelerate until I want to cruise, hit "Set" button - check
Cruise doesn't work.
Please explain. All lights are working, etc, so what do I check?
Old Oct 21, 2008 | 12:50 PM
is the cruise control light on? you might want to hold down the set for like a second or 2. are you stepping on the brake or gas? don't know what your doing wrong, seems like your doing it right
Old Oct 21, 2008 | 12:51 PM
Check whether fuse 52 under the hood is blown.
If fuse 52 is fine, do you have and know how to use a multimeter? A series of electrical tests needs to be done to locate the problem.
Is the CEL ON?
Old Oct 21, 2008 | 07:02 PM
Do you have a manual transmission?
If so, it's probably the stopper for the clutch switch has broken (don't worry, it's cheap to replace).
That's what happened to me.
oh and yea like sfazngiants said, make sure you are holding the Set button down, or pressing it twice. If you just press it real quick once, it won't do anything.
inthezoneac
Aug 29, 2008 12:50 PM
dmsteele92831
Jul 23, 2007 11:10 AM
civicracer_44
Feb 3, 2005 07:04 PM
civic9988
Oct 24, 2004 07:22 PM
frameb
Jun 14, 2004 11:28 PM
