CRYING HEADLIGHTS
Old Feb 1, 2005 | 09:49 PM
RedCityRunner's Avatar
Default CRYING HEADLIGHTS
I have a 99 civic. Nothing done to it. I had it for about a year now and i began to get moisture in the passenger side head light. I was wondering if any one else had this problem and what is the best way to deal with this
Old Feb 1, 2005 | 10:42 PM
D16z6's Avatar
Default RE: CRYING HEADLIGHTS
You might have a crack or opening some where around the light housing. Check and see if you dont have any crack.
Old Feb 1, 2005 | 11:26 PM
Super Mario's Avatar
if there are no cracks check the bulb seal, the part that sits between the bulb socket and the lampcase. Good Luck!!!
Old Feb 1, 2005 | 11:36 PM
sacicons's Avatar
and make sure the little drain holes in the boot around the bulb are pointed down.
Old Feb 2, 2005 | 02:12 PM
NTX's Avatar
NTX
be sure the seal around the lense and back is still good also.
Old Feb 2, 2005 | 04:22 PM
grncivicvtec's Avatar
And you say you have not done anything to the car, did you buy it with aftermarket headlights, cause those cheap one's dont ahve good seals or even drains.
Old Feb 2, 2005 | 09:31 PM
blackeyes's Avatar
that used to happen to my clear corners (when i had them)like they said check the seals cuz it only happened to me when it rained. i replaced mine to solve the problem though.
Cosworth
Dec 15, 2008 05:35 AM
s2000gtx
Sep 22, 2007 08:31 PM
psychocivic
Jan 26, 2006 09:10 AM
LT2004ever
Sep 20, 2004 09:37 PM
AdamC
Jun 2, 2004 04:08 PM
