D15b in civic lx sedan 96
Old Jul 19, 2011 | 01:31 PM
lpdecarie's Avatar
Default D15b in civic lx sedan 96
I just swap an engine in my civic lx 97 for a vtec engine. i just found out that it is a d15b that was in the car i bought to take the parts in (civic si vtec 96). I swapped the harness and the ecu from that car. The ecu is a p2p. i have a connector on the back of the intake manifold that i have no wire for and the check engine light is on. the car runs but i dont think the vtec works properly. i would need some help to fix the little issues since the car can run. what should i do? change the ecu or is there any wires i have to hook up. and btw i saw that the last owner did the ckf trick. thanks for your help
Old Jul 19, 2011 | 06:39 PM
You need a VTEC ECU and run the VTEC wires. Convert from 3 wire IACV to 2-wire (The thing on the back of the intake manifold). Keep the system OBDII.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
speedyturtle
Jul 20, 2007 08:20 PM
F23AccordLX
Jul 16, 2006 01:44 PM
GlennS
May 2, 2006 10:25 AM
blkgst
Mar 13, 2006 12:57 PM
