window fuse blows on start up
Old Jul 19, 2011 | 02:17 PM
pasadenaed's Avatar
Default window fuse blows on start up
Hello everyone. This is my first post to this forum. I've had this problem for about 2 weeks now. I've searched various forums and looked for an answer on the web but haven't found anything that targets my problem.
Well I own a 2002 Civic ex that keeps blowing a fuse as soon as I turn the key to the ON position. The fuse controls the front passenger power window. It's a 20 amp fuse, #23 I believe. I thought it might have been the motor that went bad and was drawing too much current so I replaced the motor with a new one and it still blew the fuse. I disconnected the terminals going to the window motor as well as the window switch on the passenger door just to eliminate those as potential problems. Well with those terminal disconnected, I replaced the fuse, turned the key to the ON position and the fuse blew instantly, without me even touching the window switch on the driver's door.
I looked to see if I could see any wires that were pinched or exposed, but i couldn't see any. Any ideas what I should check next? Is it possible that the fuse box itself has gone bad just in that one fuse slot?
Old Jul 19, 2011 | 06:51 PM
Unplug the door harnesses, driver and passenger, and try again. If the fuse doesn't blow there is a short in the door wiring, possibly where the wires flex every time the door is opened.
TexusMain
Jun 14, 2012 04:40 PM
ls40095
Nov 18, 2010 09:21 AM
civic2001
Sep 16, 2010 09:03 AM
ktm518
Apr 18, 2010 10:18 PM
wietgr
Dec 10, 2008 11:31 AM
