d15b vtec misfire help plz
Old Jan 16, 2010 | 09:06 PM
ef9101's Avatar
Default d15b vtec misfire help plz
hey guys gotta question.
its obd0 to obd1 conversion running a d15b vtec. its p28 ecu the cars been running strong for 4 months but recently 1 piston is fine on cold start but starts to misfire after its wormed up? it burns white smoke due to the excess fuel due to the misfiring. compression is fine so i figured id need to adjust the valves cuz i hav not yet since iv own the motor any comments on what problem is are welcomed please. thanks guys
Old Jan 16, 2010 | 09:11 PM
have you changed the wire and the diz cap?
sounds to me like a head gasket leak starting, cause its fine at cold starts(no pressure in the coolant sytem yet) but has a misfire after it warms up (coolant now has pressure)
Old Jan 16, 2010 | 09:34 PM
ef9101's Avatar
diz is giving good spark it shockd me pretty good when i went to unplug the cable to first while it was running lol i started thinking the head gasket to but hope no haha im try lil steps first i hope maybe the valves just got loose or maybe there tight but i dout it cause it ran great for 4 months. the exhaust fumes dnt smell lik coolent tho n before the car was cold spark plug was dry n after it was warm took it out again n it was lil wet with gas just a little bit n coolent so far thank god some i am hoping it isnt head gasket
Old Jan 17, 2010 | 09:55 AM
ef9101's Avatar
okay guys did ecu check for codes n it seems i am getting code 16 marking fuel injectors? anyone no how to fix it or should i replace injectors?
Old Jan 17, 2010 | 10:24 AM
Reset the ECU to see if the code returns.
Old Jan 17, 2010 | 06:15 PM
ef9101's Avatar
yea ron it wont go away. i replaced spark plug cables now the car runs fine but still white smoke out of exhaust n then wat seems like water coming out the tip is gass! n white smoke smells lik gas to. when i diconnect 1 piston the smoke goes away? n it isnt the injector i changed it oready so has to be somthing with wires or ecu mayb. :/
Booger
EK Swaps
Aug 9, 2011 10:11 PM
1992 civic driver
Sep 20, 2010 11:41 AM
edmaxx
Jul 4, 2010 06:27 AM
randommike88
Apr 28, 2007 09:26 PM
that_guy5
Feb 9, 2007 08:09 AM
