d15b2?
Old Dec 23, 2005 | 09:38 PM
speedstream's Avatar
Default d15b2?
anyone kno of a website that i can get the redline speeds in every gear...cause my buddy has a dx civic w/ out a tach and wants to race but not blow his engine so if he knew at what speed the gear hits redline then he can still push the car
Old Dec 23, 2005 | 10:27 PM
Belmont's Avatar
Default RE: d15b2?
D15B2
Displacement (cc): 1493
Power (bhp@rpm): 92@6000
Torque (ft/lbs@rpm): 89@4500
Compression Ratio: 9.2:1
Bore (mm): 0
Stroke (mm): 0
Cam Design: sohc
VTEC?: no
OBD: 0
Year(s) Produced: 1988-1991
In the following car(s): Honda Civic DX/LX, CRX DX
I looked for like 15 minutes but this is all i found sorry[&o]
Old Dec 23, 2005 | 10:32 PM
finalimpact's Avatar
Default RE: d15b2?
assuming your a 5spd dx with gear ratios as goes
1 3.250
2 1.762
3 1.172
4 .909
5 .702
final 3.88
along with tire size of 175/65/13
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear
500 3 5 7 9 12
600 3 6 9 11 14
700 4 7 10 13 17
800 4 8 11 15 19
900 5 9 13 17 22
1000 5 10 14 19 24
1100 6 11 16 20 26
1200 6 11 17 22 29
1300 7 12 19 24 31
1400 7 13 20 26 34
1500 8 14 22 28 36
1600 8 15 23 30 38
1700 9 16 24 31 41
1800 9 17 26 33 43
1900 10 18 27 35 46
2000 10 19 29 37 48
2100 11 20 30 39 50
2200 11 21 32 41 53
2300 12 22 33 43 55
2400 12 23 34 44 58
2500 13 24 36 46 60
2600 13 25 37 48 62
2700 14 26 39 50 65
2800 15 27 40 52 67
2900 15 28 42 54 70
3000 16 29 43 56 72
3100 16 30 45 57 74
3200 17 31 46 59 77
3300 17 32 47 61 79
3400 18 32 49 63 82
3500 18 33 50 65 84
3600 19 34 52 67 86
3700 19 35 53 69 89
3800 20 36 55 70 91
3900 20 37 56 72 94
4000 21 38 57 74 96
4100 21 39 59 76 98
4200 22 40 60 78 101
4300 22 41 62 80 103
4400 23 42 63 81 106
4500 23 43 65 83 108
4600 24 44 66 85 110
4700 24 45 68 87 113
4800 25 46 69 89 115
4900 25 47 70 91 118
5000 26 48 72 93 120
5100 26 49 73 94 122
5200 27 50 75 96 125
5300 27 51 76 98 127
5400 28 52 78 100 130
5500 28 53 79 102 132
5600 29 54 80 104 134
5700 30 54 82 106 137
5800 30 55 83 107 139
5900 31 56 85 109 141
6000 31 57 86 111 144
6100 32 58 88 113 146
6200 32 59 89 115 149
6300 33 60 90 117 151
6400 33 61 92 119 153
6500 34 62 93 120 156
6600 34 63 95 122 158
6700 35 64 96 124 161
6800 35 65 98 126 163
Old Dec 23, 2005 | 10:49 PM
Default RE: d15b2?
u kinda throw me off w/ the 6th gear thing and 5th gear @ 6000rpm doing 144mph?...thanx 4 the info guys...and if possible can u give me the link to where u found this info?
Old Dec 23, 2005 | 11:41 PM
joey's Avatar
Default RE: d15b2?
Old Dec 24, 2005 | 01:07 AM
Default RE: d15b2?
gear ratios were what ive counted after tearing down a few trannys in the past. cant remmeber what gearing calculator i used. same saying here goes for everywhere. if in doubt search. the internet is your friend
Old Dec 24, 2005 | 03:14 PM
Super Mario's Avatar
Default RE: d15b2?
Redlinig the motor won't do you much good. Your max Hp @ Xrpm is where you want to shift at. going past that X rpm is pointless. I have a 95 civic wiht a d15b7 and my max hp is at 5900 rpm. my redline is at 6200 when "racing or under heacy acceleration" i shift at 5900. let me find a link for shift speed(mph) and rpms. I'll post it when I find it.
Old Dec 30, 2005 | 12:06 AM
Default RE: d15b2?
I couldn't find the link to that website that had that stuff, But I think we need to summons the almighty SACICONS to help us here. And when we do find that link, I think it needs to be stickied. Sacicons, do you think that you can help us out here. I'm kinda interested in looking at that link again. Thanks Sacicons!
Old Dec 30, 2005 | 04:23 PM
mill$civic's Avatar
Default RE: d15b2?
i no my se came without a tach and itss because it comes with a rev limiter, it wont let you red line it
Old Dec 31, 2005 | 04:05 PM
Default RE: d15b2?
A rev limiter is basically redlining it. The rev limiter is in place so that you don't do any damage to your motor. that is the maximum RPM you can rev at without damaging your motor. Just for reference all cars come with rev limiters.
