D16y7 into an EG, and a Y8 head swap. please help!
Old Dec 1, 2006 | 09:02 AM
darknightmr2's Avatar
Default D16y7 into an EG, and a Y8 head swap. please help!
okay, i've done alot of research on this board to find out what i exactly need for this swap. i have some questions that i haven't found answers for.
1. im going from the stock D15 from my CX to a D16Y7, what do i need for the motor to run?
2. i have a D16Y8 head available. i know the head swap wouldn't be hard for a mini-me, but what head gasket should i run (keeping in mind i don't want to raise compression), what Timing belt, etc.
3. what wiring harness/ecu would i need to get this motor to run? i have the Vtec ecu from a Y8 and whole body harness from a 96 EX available. would i need to swap this out completely, or use my stock harness and wire for Vtec?
I'd highly appreciate any answers to these questions because im in the dark, and im running on borrowed time because my D15 is pretty much on the way out. thanks fellas!
Old Dec 2, 2006 | 12:36 AM
Default RE: D16y7 into an EG, and a Y8 head swap. please help!
any info is helpful. anyone? or can anybody at least point me in the right direction, and or section for these questions?
Old Dec 2, 2006 | 12:54 AM
HARI.'s Avatar
convert the d16y7 to obd1. you're gonna need to use your motor mounts and wiring harness from your d15 and mount it on the d16y7. swap the d16y8 head and use a d16z6 headgasket. you can't use the 96-00 civic wiring harness because it is obd2 and it's a one piece from the engine to the ecu. the one on your cx is a 2 piece and it's obd1. you will need to wire vtec and knock sensor. use a p28 ecu for your new motor.
Old Dec 2, 2006 | 08:24 AM
OMG thank you soo much for your help! im really in the dark about this subject, so anything helps.
1. so if i get the P28, it swaps right in?
2. do i have to find the pin outs for the knock sensor? what will i need for a harness or plug for the knock sensor, and does it just run into pin outs on the ECU?
3. which Timing belt do i need for the swap?
im also converting the intake mani from the Y7 to the Del sol Vtec intake mani that i have. since im doing so, what injectors should i use because i only have a set from a Y8 and my stock D15.
Old Dec 2, 2006 | 10:22 AM
HARI.'s Avatar
1.yes the p28 will swap right in
2. i will tell you how to wire your knock sensor and vtec. for the knock sensor plug, i have it for sale hit me up. you will also need a couple of ecu pins. i will throw that in for free w/ the purchase of the plug.
3. use the d16z6 timing belt. you can use the y8 injectors and plugs, but you will have to change the fuel rail to either the cx or the del sol fuel rail.
Aaron A Archer
Dec 4, 2011 05:30 AM
Aaron A Archer
Dec 3, 2011 03:38 PM
toughtransam36
Sep 28, 2010 05:40 PM
colby_666
EK Swaps
Mar 9, 2010 05:56 AM
sicknessjb
EK Swaps
12
Aug 14, 2009 04:15 PM
