Damn noise comming from drivers side front wheel
Old May 7, 2006 | 09:46 PM
Fiirkan's Avatar
Default Damn noise comming from drivers side front wheel
ok, i am trying to diagnose a noise that is comming from the front drivers side wheel, everytime i go over a bump at lower than 70kph(well it could be higher speed but i can't hear it then), i hear a "thud", now this happens wether the wheel is straight or turned in either direction. i have jacked the car up and looked at it but can't see anything, the cv boot looks ok so i don't think that it is the axle, the spring it fully intact, and everything looks to be in proper order. now i don't know if this is linked to the issue, but i need to replace my break pads on the drivers side cause i am sure that they are almost completely gone. but then again i have to change the passenger dies ones too but i hear no noise from the passenger side. i will get some piucs of the underside soon to see if someone can solve the "spot the problem" puzzel... any help is appreciated[8D]
Old May 7, 2006 | 11:04 PM
Default RE: Damn noise comming from drivers side front wheel
i'm having the same problem fiirkan but mine is on the pass side just a thud every now and then i think mine is a leaking strut i almost didn't see it its not leaking that bad that might be your problem i have checked my cv/tie rod ends / hubs /every thing sorry i couldn't help
Old May 7, 2006 | 11:26 PM
AgentofDarkness's Avatar
Did you guys check to make sure the bushings are greesed? Ungreesed or worn out bushings will cause noises to come from suspension compenents.
Old May 8, 2006 | 06:16 AM
yes i checked my bushings now the pass side strut is leaking a little worse so i think thats it .my car has 137.654 miles on it so i think its time for new struts thanks agent
Old May 8, 2006 | 07:36 AM
Fiirkan's Avatar
hey agent how would ungreesed or worn bushing look like exactly, cause i looked at the bushings but wasn't surwe if they were ok or not
Old May 8, 2006 | 07:22 PM
they would be dry and cracked and both my back bushings in the lower control arm are cracked bad so its replacement time
Tommyboy1
Apr 21, 2013 04:34 AM
Tommyboy1
Apr 20, 2013 02:23 PM
Kiwistalker
Mar 28, 2011 10:22 AM
JasonEJ8
Mar 30, 2010 04:43 AM
Naudlee
May 26, 2006 09:44 PM
