Darn Squealing belt
Old Jan 31, 2011 | 04:22 PM
canyonmom's Avatar
Default Darn Squealing belt
I hate this sound! Please tell me how to fix it before I go nuts! It sqeaks when I start it up in the morning, now the squeak is getting londer.
Old Jan 31, 2011 | 04:29 PM
civicexracer's Avatar
Check your belts.. Visually inspect them for any wear/tear before you tighten them, may need to replace them. If they look good, press down and also twist them to see if they're loose. Find the one(or more) that's loose and adjust them. Pick up a Haynes manual, it's an easy job.
Old Feb 1, 2011 | 01:48 AM
canyonmom's Avatar
Thanks I found lots of post about the belt situation. I do have the manual, just not sure what to tighten. all the bolts are tight. What about belt dressing? or is that a temp fix?
Old Feb 1, 2011 | 03:26 AM
Mecca8383's Avatar
Download the Honda manual from the forum & find the section that tells you how to replace the belts, from there it should tell you what bolt(s) you need to adjust to get the belts tight. I have a feeling it's the alternator belt...it usually is.
BTW...are the belts in good condition (not cracked or frayed)? Know that before doing anything.
Old Feb 1, 2011 | 10:14 AM
canyonmom's Avatar
Yes they are new belts. Thanks!
Old Feb 1, 2011 | 10:17 AM
canyonmom's Avatar
ok where do I find the manual?
Old Feb 1, 2011 | 10:19 AM
canyonmom's Avatar
duh found it!
Old Feb 6, 2011 | 06:26 AM
canyonmom's Avatar
My son came and fixed it, it was the altenator belt! Yippee!
bobackwards
Jul 19, 2011 06:29 PM
trustdestruction
Aug 30, 2009 05:18 AM
fuzzlaw
Oct 3, 2006 06:19 PM
Kov
Jun 29, 2006 03:14 PM
laminatedfrog
Apr 15, 2005 01:23 AM
