Dash emergency break light. Its stuck on.
Old Aug 11, 2008 | 05:30 AM
nathanclark80's Avatar
Default Dash emergency break light. Its stuck on.
For some reason, my emergency break light is stuck on. I have tried engaging and disengaging the emergency break, but the light
stays on. Has anyone seen this before?
Old Aug 11, 2008 | 06:21 AM
That light also indicates other problems with the brake system. Most likely the brake fluid level is low.
Old Aug 11, 2008 | 07:43 AM
Either that or the switch is stuck. That happened on my 2000 DX. I had to pull the arm rest and clean the button.
Old Aug 11, 2008 | 08:36 AM
Awesome! Thanks for the tip.
Old Aug 11, 2008 | 10:55 AM
dito. check your brake fluid level first and if its low simply fill it up and if the light goes off your all good. if it stays on pull the center console rear section and check the switch on the ebrake.
AndrewAR
Mar 13, 2011 07:59 AM
coolfez
Feb 28, 2011 07:13 PM
KFRG
Feb 7, 2010 03:28 PM
rit14623
Jan 10, 2007 10:48 AM
