dash lights gone out help!!
the lights behind my speedo and fuelgaugetemp gaugehave gone out. can anyone tell me where the fuse is as this is probably the most obvious explanation. i know the fuse is under the steerin wheel but im not sure of the exact one. i drive a 96 ek 3door 1.4. uk spec. any hlp much appreciated. a link to a diagram mite help too!!
Edit: First before you do anything make sure that someone just didn't turn the dimmer all the way down.
Check if the tail lights work first. If the tail lights work and the fuse is good, pull the brightness control out of the dash, unplug it, and jumper the red wire to the black wire in the plug. The dash lights should come on full bright. If they do the dimmer control is bad.
My car had a similar problem. I found that the wires from the harness that connect to the cluster had worn off in some places and were shorting out. I replaced fuse #15 and it worked like a charm. My car is a 00 si so yours may be similar.
itzcorky
Nov 13, 2013 06:26 PM
itzcorky
Sep 21, 2011 07:45 AM
gsnidow
Apr 17, 2011 10:17 AM
