diagnostic hookups
Old Jul 2, 2009 | 02:06 PM
koverton's Avatar
Default diagnostic hookups
94 Civic DX
Where are the diagnostic plugs?
Old Jul 2, 2009 | 02:17 PM
diagnostic plugs? Are you talking about an OBD-II DataLink Connector?
Old Jul 2, 2009 | 02:27 PM
koverton's Avatar
yes the OBD connector
Old Jul 6, 2009 | 09:59 AM
The '94 is OBDI. It will not interface to an OBDII scanner.
To check codes, locate the test plugs above the ECU on the right side of the car under the dash. There are 2 plugs. The one with 3 wires is for a proprietary Honda scanner. You want the other one with 2 wires. Jumper the pins in that plug with a test wire. Turn on the key (do not start engine) and the code number(s) will blink out on the CEL.
JerZy
Apr 5, 2009 06:52 PM
m0rgansciv
Jan 17, 2008 10:07 PM
civic_burns_all
Nov 6, 2007 12:14 AM
dinanrob
Sep 20, 2007 02:04 PM
ohbiskits
Jul 25, 2004 05:12 PM
