Distributor Ignition Corrosion, please help
Old Jan 26, 2006 | 06:51 AM
rodbuster's Avatar
Default Distributor Ignition Corrosion, please help
'93 civic ex coupe 1.6 v-tech, has aftermarket msd ingnition and msd blaster coil, msd dist cap, wires and platium plugs. have continious problem with a greenish film of corrosion forming on contact tips inside the cap that meet the rotor, on the end of the rotor button and will build up to the point it will seize the coil contact carbon stem inside the cap to the cap housing. Corrosion is so bad it will not start until cleaned from areas and will re-form in less than 100 miles of driving. Have tried silicone dielectric greases, anti corrosion grease to no avail. Any ideas or help much appreciated...Thanks
HondaFamily2
May 31, 2010 05:39 PM
lifelong99
Nov 12, 2009 10:43 PM
Alphadawt
Mar 26, 2007 09:21 PM
tlkolrod
Feb 14, 2007 12:19 PM
crimsonnblue
Dec 10, 2006 09:02 PM
