door key lock problem
Old Dec 1, 2007 | 02:13 PM
2003civicLX's Avatar
Default door key lock problem
I just bought an 03 LX Sedan and I am trying to fix a problem.
The driver side door lock only works 1 out of 10 trys with the keys. The key works fine in the passenger side door and in the ignition.
Does anyone know what might be causing this?
Old Dec 1, 2007 | 05:25 PM
Default RE: door key lock problem
If you are saying that you can't turn the lock with the key because the lock is sticking, then I would suggest that you purchase some graphite lubricant for locks and spray some into the lock where you insert the key. Then insert the key and work it to loosen the lock mechanism.
redraif
Mar 7, 2013 01:59 PM
Amateur
Nov 2, 2008 03:13 PM
shiaokaz
26
Jul 7, 2008 06:44 PM
shiaokaz
May 9, 2008 01:13 AM
Koala
Oct 12, 2007 09:38 PM
