Dragging Clutch???
Old Apr 26, 2008 | 12:37 PM
jprommel's Avatar
Angry Admin
Default Dragging Clutch???
(97 ex coupe) when my car is in neutral and i release the clutch i hear a slight scraping sound. also when i have the front of my car jacked up and the engine is running the front wheels spin. what could be the cause of this and how do i fix it. TIA
Old Apr 26, 2008 | 04:17 PM
colby_666's Avatar
Default RE: Dragging Clutch???
sounds to me like your clutch is not disengaged all the way when you let out the petal, did you get a new clutch recently? i believe you can adjust the cable, someone else would know better than me but good luck
Old Apr 26, 2008 | 04:33 PM
jprommel's Avatar
Angry Admin
my clutch is hydraulic, and no i did not just get a new clutch although i did replace the slave cylinder for it about a month or two ago. I'm thinking that maybe i might just need to bleed it again because there might be air bubbles still, but i'm not positive and i would like the input from the people that know a hell of a lot more than i do about civics.
Old Apr 26, 2008 | 04:57 PM
When a clutch is truly dragging it will be very hard to shift into gears, especially reverse. It can make the car impossible to drive (well, in the normal manner anyway). Since you didn't mention that I assume it is not happening.
I think the noise you are hearing is worn bearings in the transmission. With the clutch pushed in it goes away because the transmission stops turning.
It may be normal for the wheels to turn as you describe, never tried it. When everything is moving freely it takes very little torque to do that. Anyway this would be an issue with the transmission not the clutch.
Old Apr 28, 2008 | 04:38 AM
jprommel's Avatar
Angry Admin
If it is worn bearings in the transmission is it an important thing to get fixed or could i just let it slide. Also could someone check on the wheels rotating while the car is up in the air and the engine is running???
hekla
Feb 18, 2009 07:23 AM
ErikElvis
Dec 8, 2007 09:44 PM
snosurfa7
Jun 12, 2007 09:31 PM
snosurfa7
Jun 9, 2007 01:18 PM
mcoulter
Oct 18, 2006 11:24 AM
