Driver window
ok, my window, like so many other peoples is not working correctly. Im almost positive the bolts werent put in right when i had it replaced. I took the window out but one botl is still sitting in the clip, and i cant get it out. It just keeps spinning inside it, how do i get it out, this is making me more angry than anything ever.
Is this one of the two bolts that secures the window to the regulator (see picture)? If so, is it possible to remove the entire window regulator to make it easier to extract the bolt?
[IMG]local://upfiles/25538/89D44172DF764A5CA275BA5B2ED34E1E.jpg[/IMG]
it is one of those, i have the entire window out, its just one bolt, on one of the clip things, and i even tried to dremel the damn thing off but my dremel broke, i took it to oreilly and they said to try and drill it out but i have no drill and they said they dont have one either, wow
Yeah, I completely understand the frustration. Get some rest and tomorrow morning try to borrow a drill and metal bit from a friend so that you can extract the bolt. Take your time so you don't damage the window. Good luck.
Supreme_Reverend
Jan 12, 2006 01:25 PM
LEVIII
Aug 8, 2005 10:09 AM
