dropped engine in and cant get it to crank over
Old Aug 28, 2011 | 07:21 PM
poloman's Avatar
Default dropped engine in and cant get it to crank over
i have a 92 eg hatch pulled out a gsr out of it dropped a valve got my lsvtec in it went to crank it over and im not getting notting when i turn the key over so checked fuses and notice the the whole engine had a positive charge on it when i checked it. so my question is has anyone had this problem could it be my ecu its the same one i had on for the gsr or what could it be, i also cant hear the fuel pump turn on when i turn the key, i have power in the dash, and i disconnected the starter and the alternator n the engine still has the charge
Old Aug 28, 2011 | 07:31 PM
That "charge" means that the engine is not grounded to the battery. Check the main ground wire from the transmission to the battery minus (it also tees off to ground the frame).
Also it's very common to forget to secure the little ground wires on the thermostat housing, that will prevent starting though the engine will crank.
Old Aug 28, 2011 | 07:44 PM
poloman's Avatar
its grounded off on the thermostat housing the valve cover n the tranny n the whole tranny n block have a charge up to where the ground cables are connected
ZeMo
Oct 25, 2011 10:23 PM
zerojett
Oct 18, 2011 03:01 PM
whitworthsean
Nov 8, 2007 09:22 PM
Boost231
Feb 11, 2006 07:14 PM
US3R!!!11one
May 7, 2005 04:35 PM
