dual point to multipoint conversion sohc vtec swap PROBLEM
Old Feb 19, 2010 | 05:38 AM
norbster86's Avatar
The TPS is definitely a suspect. If the comp isn't reading it right, you open the throttle, lean out the mixture and your engine dies - more air and same amount of fuel.
You can check the injectors by unplugging them one at a time. If you unplug one and there is no change in the idle, you found a bad injector. I don't think this is the problem anymore.
Old Feb 19, 2010 | 07:55 AM
check and make sure that the tps and the map sensor plugs aren't switched. they have the same plugs.
Old Feb 19, 2010 | 11:12 AM
str8jdmswap's Avatar
which is which. were are they located
Old Feb 24, 2010 | 06:04 PM
any ideas???
Old Feb 24, 2010 | 06:53 PM
tps sensor is on the throttle body, and map sensor should also be in that area, google tps sensor and map sensor for a civic if u need a pic of what they look like. do you have a cel??? look at you ecu and count the red blinks. post results
Old Feb 24, 2010 | 11:17 PM
ok. yeah found them. and there rite. and i do have a cel. i got codes 6 and 10
Old Feb 25, 2010 | 05:08 AM
how did you get the codes??? JUSt want to make sure u did it right.
each 1/2 sec blink =1 and each 1 sec held blink = 10
6: ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
10: IAT Sensor (Intake Air Temperature)
unplug the battery to reset the cel codes and start the car back up and let it run, pull codes again to see if they both come back.
Old Feb 25, 2010 | 08:35 AM
now it wont even start. i have a voltage meter. and i checked my fuel injector plugs and nothing.. and io even went str8 to the ecu. into the little pins. and still nothing.
Old Feb 25, 2010 | 08:37 AM
i watched blink 6 times. then it blink ten times. not sure if they were a sec or 1/2 a sec. i'll check.
Old Feb 25, 2010 | 09:07 AM
yea you didnt count the blinks right, each fast blink =1 and each long blink =10
so if it blinks 1 long blink then 4 fast blinks that will = 14
also check your fuses
