dual point to multipoint conversion sohc vtec swap PROBLEM
Old Feb 25, 2010 | 03:44 PM
  #21
str8jdmswap's Avatar
in that case. i got codes 12(exaust gas,etc.), and 20(electric load). how would i fix this problem?
Old Feb 25, 2010 | 04:17 PM
  #22
12: EGR Lift Sensor (Exhaust Gas Recirculation)
check the hoses, the EGR valve lift sensor and the System EGR valve.
20: Electrical Load Detector
defective circuit or unplugged / defective sensor
http://www.civicforums.com/forums/21...-detector.html
Old Feb 26, 2010 | 11:13 PM
  #23
tomarrow im gonna go ahead and buy the complete ef si wiring harness. i found one for about 80 bucks. so im getting it. because mine has so many plugs unplugged. and i cant find the plugs to go in them. so im just going to get this wiring harness.
Old Feb 27, 2010 | 06:50 AM
  #24
the si harness will not work with your car, all the si harness is good for is to cut up amd add to yours, you keep the dual point harness and just add the injector wires and the 2 distributor wires.
if you need help pluging stuff up take pics and post them up i can help you.
str8jdmswap
ED-EF Swaps
Jun 15, 2010 09:46 AM
clydesteve
Jun 14, 2009 03:06 PM
knfdeals
Feb 20, 2007 01:19 PM
knfdeals
Feb 19, 2007 07:44 PM
barryscivic
Aug 9, 2005 11:20 PM
