E-Brake Not Working
Old Dec 10, 2008 | 11:44 AM
Justin13's Avatar
Banned
Default E-Brake Not Working
My e-brake works very very little when i pull it up. i tryed tightening it but all that did was make it so it didnt pull up as far and made it worse. any ideas?
Old Dec 10, 2008 | 01:27 PM
One of the cables may be stuck. The next step though should be to pull the wheels and inspect the rear brakes. You may need new brake shoes or the self-adjusters aren't working. Then you can also see if the cables move at the brakes when you pull the handle.
Old Dec 10, 2008 | 01:46 PM
dito.... quick test is to pull the console cover and pull the brake and see if both of the cables move ruffly the same! if one moves more than the other then most likely the cable snapped... just confirm it by pulling the wheels off and pull the drums off and have someone pull the brake handle to make sure the cable doesnt move.... then just pull the cable and replace it. it probably got dry internaly and just snapped or binded one time when you pulled it... it happens. cheap enough to replace. and then be sure to readjust the cables with your new one in. you dont want the ebrake to be draging the brakes and wear out your rear pads really fast and posibly warp the drums.
Old Dec 10, 2008 | 06:16 PM
Justin13's Avatar
Banned
sounds like alot of work
Old Dec 11, 2008 | 01:35 AM
not really.... replacing the cable will take about 30mins or so.
NellyBly15
Dec 8, 2018 07:05 AM
asdf
Jul 23, 2012 04:44 AM
wcthattan
Sep 20, 2010 09:27 AM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
