Ecu
Old Dec 3, 2009 | 07:47 AM
Jason D's Avatar
Default Ecu
Ok i did the trick to the ecu to tell it that the crank sensor is hooked up. well anyway its an obd1 motor in a obd2 car so i had to do the trick to the ecu. so the check engine light went off then i started it and it came back on. i tryed to do the jumper thing in the little green plug to see if i could get a code but the the light never blinked. am i doing something wrong or maybe my wires disconnected on the ecu, im just lost lol
Old Dec 3, 2009 | 07:51 AM
is it running better now?
Old Dec 3, 2009 | 08:12 AM
Jason D's Avatar
ya it dose run better it dosent buck like at all. the vtec isnt hooked up yet cause i still need the p28 but how come my check engine light is still on?
Old Dec 3, 2009 | 09:27 AM
im not sure why, but prob cause the sensor is bypassed, have you tried unpluging the ecu for a min then plug it back up to reset the ecu and try it again
Old Dec 3, 2009 | 09:53 AM
Jason D's Avatar
ok so just leave it unhooked completely for a little bit? like if i turn the car off for a little bit the light gos off but like 2 secs after i start it it comes back on
Old Dec 3, 2009 | 12:28 PM
Jason D's Avatar
i think i know what i did wrong. i connected the wires that run to that ckf sensor instead of the wires on the ecu. so if i understand right i gotta hook up the wires comin from the plug not the ones that go underneath the hood. Am i right?
Old Dec 3, 2009 | 08:12 PM
if thats what that link said to do,
Old Dec 4, 2009 | 01:12 PM
Jason D's Avatar
ya im not sure cause its not in that detail and im not understanding how they are explaining it. so the car dosent run any better so im thinking thats what i gotta do lol
Old Dec 8, 2009 | 04:09 PM
Jason D's Avatar
so i went to autozone to see what the check engine light was about, and they told me that the cam fluctuation sensor is not getting any signal. was that because of the ecu trick?
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
