ef piston problem HELP!
Old Dec 22, 2008 | 10:17 AM
  #31
Originally Posted by ef9101
i was sure i new which fuse to pull but now im not lol weres the harzard fuse located before i pull somthn im not supose to
I think it's fuse #34 in the main fuse box:
Old Dec 22, 2008 | 10:21 AM
  #32
...one question wat if the 0xygen content to cata doesnt turn out to be the prob wat else uthink could be going on
Which problem do you mean here -- the code 1 problem or the cylinder 4 problem?
Old Dec 22, 2008 | 10:28 AM
  #33
out of curiousity ...whats supose to happen when u disconnect an injector cuz i disconnected the main when cars running n nothing happend ...i re connect it n go to disconnect aux.injector n the car wants to die so ima head to the wrecking yard right now to grav a main injector
Interesting. Before replacing the main injector, you first might want to test whether it clicks, has the proper resistance, and is getting battery power (see diagrams above). I believe the main injector supplies fuel to cylinders 3 and 4. Do you think the engine would run on two cylinders?
Old Dec 22, 2008 | 07:46 PM
  #34
ef9101's Avatar
i think the main only controls # 4 n i replaced the injector i dont think the harnes is giving power for it cuz i disconnected the aux injector n it was dieing out all the cylinders so theres a problem with the main injector harnes wire i think that my problem
i dont hav money for a new harness so ima hav to hold on that
evrythink else is fine now ima run a test on the line tomarrow see if its getting power
besides that i think my problems solve i hav a main injector situation
ef9101
Dec 21, 2008 11:23 AM
demonicangel079
Jul 29, 2008 07:21 AM
WhiteBoyzRacing
Oct 1, 2007 08:49 AM
t34me
Aug 17, 2006 03:11 PM
alva
Sep 11, 2004 10:54 PM
