Electrical Problem
Old Mar 19, 2014 | 06:16 PM
LuisV's Avatar
Default Right Headlight Really Dim
Hello guys Im new to this site
I own a 2005 Honda Civic Lx Sedan-automatic
Recently came a cross a real annoying issue and electrical problem.
I didn't know much about how electrical cabling worked
so I hooked up my fog-lights to one of the headlights worked great for months
recently I wanted to add HID's but noticed that my l
right headlight(the one hooked up to the fogs was really really dim) I unplugged the fogs and the problem persisted I did a check on the ground wire and it's fine it seems to be the red wire(+) that is not getting enough volts through.I did a bypass the bulb and the ground wire are fine.
Old Mar 19, 2014 | 10:17 PM
itburnswhenIP's Avatar
make sure socket connection is good. do you have a volt meter ?? you can also try swapping the bulbs to see if its the bulb itself. also check relays.
Sporange
15
Jan 12, 2007 01:07 PM
93HBEX
Jun 16, 2005 01:45 PM
civicgolg
May 24, 2005 04:13 PM
thirddensity
Jan 31, 2005 03:19 PM
Norman_x
Dec 8, 2004 02:09 PM
