Engine fans run when heater turned on
Old Sep 18, 2008 | 06:34 PM
Rob M's Avatar
Default Engine fans run when heater turned on
A few weeks ago I bought a new 2008 Honda Civic LX, manual transmission with A/C.
I've started using the heater now that it's cool in the mornings. I notice that when I turn on the heater, both the AC fan and the engine cooling fan cycle on and off every 15 seconds or so. It's definitely related to turning on the heater. The heater temperature and fan speed don't seem to make a difference.
Is this normal? I can't think of a reason why the engine fans would start when the heater is turned on. If anything, the opposite should happen.
Thanks,
Rob
Old Sep 20, 2008 | 07:09 AM
When you select defrost, the A/C runs to dehumidfy the air before it is heated and applied to the windshield. This clears fog off of the inside of the windshield much better than just warm air would. Nearly all newer cars work that way. The older Civics do not automatically link the A/C to the defroster. If you select the floor outlets instead of the defroster it should just be heat then.
Old Sep 20, 2008 | 12:33 PM
Rob M's Avatar
Hey thanks a lot, you're absolutely right. I appreciate the info.
tgs
Mar 28, 2010 07:12 PM
samilitant
Jan 8, 2007 10:47 PM
romic00
Dec 3, 2006 08:06 PM
tsh30039
Sep 30, 2006 02:45 AM
Remmy
Mar 6, 2005 01:18 PM
