Engine Light Came on - Heat O2 Sensor
Old Dec 8, 2004 | 01:36 PM
mytsurfer's Avatar
Default Engine Light Came on - Heat O2 Sensor
My light came on and I noticed that the car was idling really made when in neutral. I took it to Autozone for the free diagnostic check. They said it's the Heater O2 Sensor. I know where both sensors are located, just wanted to ask if anyone's has had this problem before and can confirm that all I need to do is to change out the sensors (if someone can suggest which one it probably is that would help too), or if the problem might be something else. I called a local automotive repair and they want to charge $90 buchs to run a full diagnostics and then $250 to replace just the top sensor if that's what comes up.
Old Dec 8, 2004 | 03:32 PM
mytsurfer's Avatar
Default RE: Engine Light Came on - Heat O2 Sensor
I don't think it matters but its a 97, 4 cyl, automatic. 1.6L
Old Dec 8, 2004 | 05:56 PM
sacicons's Avatar
it should be just replacing it/them. i had the same code on my 95, but it was right after i did a clutch, and i found out afterwards, that i had pulled a wire out. if you know someone else with a 96-00 civ, switch them one at a time and see if it fixs it and then buy the one that is bad.
Old Dec 8, 2004 | 09:35 PM
kjreinha's Avatar
I had my Engine light come on in my '96 civic and received the message about --low catalyst efficiency in bank 1...p0420 code I think...
Anyway, Autozone told me it was the O2 sensor (s) but in actuallity it turned out to be either a plugged-over-time catalytic converter (170,000 miles) or the more probable cracked exhaust manifold attached to it. I replaced the manifold and subsequent converter for about $225 (a Dorman replacement unit ordered onlin, a non-California approved model) and the cleared the codes. The car runs great, the light is gone and the same old O2 sensors ar in the car.
Just food for thought.
Good luck
KR
Old Dec 9, 2004 | 07:35 AM
mytsurfer's Avatar
Thanks for the advice. I went ahead and changed the one before the coverter (took all of 5 mins) and the light went off and the car is running a lot better now. I'm glad I picked the right one and I didn't pay over $300 to do it.
firecatf7333
33
Apr 18, 2009 11:05 PM
inthezoneac
Apr 1, 2009 06:32 PM
JakeyMan07
Aug 24, 2008 01:11 PM
EWilliams2000Excoupe
Sep 21, 2007 02:46 PM
94civicexvtec
Jul 11, 2007 09:11 AM
