engine light + rev limiter at 4k rpm?
first off, no im not hitting my rev limit at 4k RPM.
ive been having issues with my engine lately. the first batch was solved with a primary 02 sensor as opposed to changing both 02 sensors and cleaning this and that for $800 like my mechanic wanted. i was throwing misfire codes and catalyst below threshold codes.
so i changed the 02 sensor and things were going fine. 3 weeks later ive got a new problem, and the code i got was P0335 - "Crankshaft Position Sensor A Circuit Malfunction". every once and a while my car acts up randomly drops about 500 RPM for a split second, jolting the car. othertimes it acts like there's a rev limiter, usually around 4000 RPM. there is no pattern according to when it happens (ie: weather, engine temp). im completely lost and need help!
i really dont want to take it to a mechanic either... im not that rich
edit: its a 2001 5 speed / 1.7 litre sohc vtec
It sounds like you have a problem in the crankshaft position sensor (or circuit) from the description of the code. It seems like everyone once in a while your computer is getting a BS reading from teh CPS. Since you have an intermitten problem it will be tricky to diagnose especially since you don't know the conditions under which the problem occurs. If you can recreate the problem on command it will be really help in diagnosis. Anyway, i would start by tracing the wires from the CPS back to the wherever it is they go (prolly the PCM). THis problem could be caused by a problem in the wiring (loose/broken connection). You don't want to change the CPS sensor (which isn't gonna be cheap) to find out it is still broken. So first look for loose/broken connections or broken wires. A wiring problem will send false readings to the computer which will cause your engine to do wierd things. If you are positive that the wiring is not the problem, then i would say that your sensor is malfunctioning.
If it is the CPS, I actually have to add one to my car, the sensor itself is about $100, but unless your handy with mechanics its a bit of a pain toget to. Its located on the oil pump. I mean the parts are cheap but labor is a mother. You have to take off all the accesory belts and everything to get the Timing belt cover off to get to the oil pump and CPS. The sensor is held in by two bolts though and once you get to it , it shouldn't be too big of an issue. Big up a haynes manual and see if you have the audacvity to do it yourself
interesting - thanxs for the post and to Agent for his post.
some kind of engineering
thought they were off of the flywheel (or maybe some are).
here is a look at one such (not honda)
http://www.v8sho.com/SHO/CrankshaftP...sorRemoval.htm
http://experts.about.com/q/Nissan-Re...alfunction.htm
and autozone (91 - 98)
http://tinyurl.com/pql7w
acf7efi
Oct 10, 2021 03:34 PM
MikeDun
Mar 28, 2011 07:10 PM
browncivic
Nov 17, 2008 08:57 PM
