Erratic Speedometer and shifting!!
I tried seaching but no one ever said what the problem was and if they ever fixed it. I figured someone might be able to help.
I have a 97 dx auto w/140k and speedometer stays at 0mph or if it does read it jumps around like crazy. The check engine light is NOT on. I wouldn't mind if it didn't affect anything else but say im doing 30mph and the speedo is jumping, it will shift gears erraticly. I changed the vss and it still has the same problems. Also the car surges or pulses and ALL the lights on the car are affected from the cluster to the tail lights. A few times it was so bad that the light for the gear indicator on the cluster would blink.
just went and checked. It isn't blown but the fuse just about fell out!!! it looks like it melted the fuse holder a little bit...now what???
The good news is that you found the problem. The bad news is that there is a short somewhere in the important fuse 15 circuit and that this short may have fried the under-dash fuse box. Based on your description of the fuse box damage, it may need to be replaced. Nonetheless, this may not be the underlying cause for the short. Reading the Service Bulletin at the link below is the first place to start:
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
By the way, did you have a 7.5A fuse in the fuse 15 slot?
An area of the black/white wire was somehow damaged and grounded out.
I am currently waiting for the fuse box to arrive. I only replaced the wire from the fuse box to the connector on the strut tower. I checked the from that connector to underneath the intake manifold and it didn't seem damaged so i figured it would be fine. It didn't short to ground or to any other wires so hopefully its fine.
