Evap code p1456 only when tank 1/2 full or lower
Been getting this code for a while. Things I've tried:
New gas cap
New filler neck (had small leak where attaches to hose)
New two-way valve
New bypass solenoid
Been monitoring it with an elm327 iPhone obd2 reader. Shows evap test passes until gas tank is half full or lower then the code throws again.
Could there be another small leak that the system only sees when under a greater vacuum?
New gas cap
New two-way valve
New bypass solenoid
rbaldwin7
Oct 23, 2013 05:03 PM
brandonv
Dec 26, 2012 11:02 AM
aeromang
Apr 15, 2009 12:48 PM
rkzimmerman
Dec 13, 2007 05:12 AM
