ever forget to install the side motor mount
Old Nov 25, 2008 | 09:39 AM
klawrence's Avatar
Default ever forget to install the side motor mount
whoops -- got my timing belt cover and crank pulley and accessory belts all back on ('cept steering pump), and then realized I hadn't installed the little bracket that mounts to the head and pokes through the timing belt cover's hole to provide a mounting point for the upper side motor mount. Anyone else ever done this? Dammit!
Old Nov 25, 2008 | 06:59 PM
whoknows's Avatar
Nope I think you are the only one.
Old Nov 26, 2008 | 06:16 AM
I did swap a '95 engine into my '91 and then realize the mount was different and had to replace it. Really there's no reason to remove that piece in the first place unless you're putting the engine into a different car like I was or trading in the head for a rebuilt one.
If you're just taking the head off to replace the head gasket, leave everything attached to it: manifolds, sensors, etc. Some people don't even bother to remove the lower timing cover, just slacken the belt and take the cam pulley off.
Old Nov 26, 2008 | 11:23 AM
i almost did when i had the 94 z6 pulled to replace it. luckely i noticed it before i got ready to drop it in the car.
i need to replace the motor mount on my y7 eventualy... its poped and kinda messy tho i think most of the internal oil has finally leaked out mostly. just one of those eventualy ill replace it things.... just like my axle.lol
drbyers
Nov 13, 2006 04:23 PM
315 Customs
Oct 17, 2006 08:22 PM
Auto98EX
Oct 12, 2005 08:34 AM
Super Mario
Jun 3, 2005 12:01 AM
Redcivicowner12
Aug 27, 2004 04:12 PM
