Exhaust questions
trying to get a little info so i can round up the last little bit of parts for my swap. so i have a 1992 4dr civic and im putting a h22 in it. i know that i need the h22 header but for the rest of the exhaust system do i have to use a civic system or can i use the prelude system with ease? or would it just be more wisely to go to an exhaust shop and get a custom one?im a little scared about how much the shop would charge to fab one up so any and all help in this area would be appriciated.
you need the civic catback and catalytic converter. for your civic, you can get a magnaflow high-flow cat on summitracing.com and it will have a spin flange (the flange going to the header from the cat rotates, allowing you to adjust it to your setup for a perfect fit), which should make installing it onto the h22 header a lot easier. I recommend buying this.
WILMER007
Dec 24, 2008 11:46 PM
FRESH96
Dec 12, 2007 09:18 AM
