Exhaust questions.
Old Jan 31, 2011 | 09:29 AM
StonedCold's Avatar
Default Exhaust questions.
Ok, I have a 99 DX and it's cat is clogging up. It's got the manifold cat combo unfortunately.
I also have a 95 EX that at the moment has a hole in the side of block.
Will the exhaust off the 95 fit the 99? Or just a few pieces? How hard will it be to swap the whole thing?
Old Jan 31, 2011 | 09:35 AM
StonedCold's Avatar
I have no cash at he moment to spend on this.
Old Feb 1, 2011 | 05:33 AM
StonedCold's Avatar
nobody knows if the 95 ex exhaust will fit a 99 dx?
Old Feb 1, 2011 | 07:30 PM
It would generally fit. The center pipe under the car after the cat would need to be modified to mate with the back of the cat. (I don't think the 95 pipes from the cat back will fit the 99 body) You will need to install a bung for the second O2 sensor after the cat. Also the wires for that sensor need to be extended.
First though, fix the rich run or misfiring problem that damaged the cat, or you're just going to ruin the new one too.
alanking80
Apr 30, 2012 03:37 PM
WILMER007
Dec 24, 2008 11:46 PM
FRESH96
Dec 12, 2007 09:18 AM
oldguy
Mar 17, 2007 01:03 PM
Msjessica
Jan 15, 2006 04:45 PM
