failed emissions, what should i do?
Old May 8, 2007 | 04:52 PM
DXhatch's Avatar
Default failed emissions, what should i do?
I took my car in for the test, but i failed the idle part. What should i do? Any tips or tricks, i dont want to fail it again. As i was looking around in the engine bay i found out something that may have contributed to the performance. This is what i found. Where does the other end go to? I also noticed two plugs next to my ecu that wernt plugged up, is it supposed to be like that? I also posted a pic of the emmisions test. Please help me with this.
[IMG]local://upfiles/17553/6B3DD1BF0F16426D80F890B65FC5FB82.jpg[/IMG]
[IMG]local://upfiles/17553/5AC1CC8EA4B0489398814AF6FD232A59.jpg[/IMG]
[IMG]local://upfiles/17553/BE0E33D1B9B24C19BD3BE06BEBB8EE3C.jpg[/IMG]
Old May 8, 2007 | 05:30 PM
Stimpy's Avatar
Default RE: failed emissions, what should i do?
here's where that tube goes in my car (red arrow)
My CX failed emmsions, about the same % on HC but not as bad on CO. It also failed during idle. I changed oil, used seafoam in gas and oil, changed plugs, cap and rotor, cleaned the battery terminals, and ran it on premium gas. (not sure if the gas did anything, but some ppl recommended it) It passed when I brought it back in.
Good luck!
[IMG]local://upfiles/8477/12A5BA1DA5EF4831A871B9584E7DD43A.jpg[/IMG]
Old May 8, 2007 | 05:36 PM
DXhatch's Avatar
whats the hose for anyway? Because the piece that the hose goes on seems to be broken.
Old May 8, 2007 | 05:48 PM
Stimpy's Avatar
looks like it connects to one side of the pcv valve. I'm not an engine guy, but I know that has something to do with reducing emmisions.
Old May 8, 2007 | 06:40 PM
gin0o0o's Avatar
Yeah if you remove that hose which is used in the Seafoam treatment where you suck it through the pcv valve it should reduce emissions dramatically. Dads friend showed us this trick since he works at an inspection center. We simply unhooked the hose and emissions dropped like 200%, seriously.
Old May 8, 2007 | 09:33 PM
DXhatch's Avatar
so you think thats not the reason why i failed? I didnt mention this but before i had the test taken i did the following, changed the oil, transmission iol, changed spark plugs, oil filter, and filled up with premium. I dont get it!
Old May 9, 2007 | 04:04 AM
Stimpy's Avatar
how did the plugs look when you removed them? might want to try a compression test if you have a gauge laying around..
Tiran
Feb 27, 2009 04:24 PM
kidintheshadows
Aug 13, 2008 12:55 PM
Stimpy
Apr 25, 2007 07:09 AM
bmxedup
Feb 2, 2007 09:40 PM
Sik 6
Nov 9, 2005 03:02 PM
