A few gen tech questions.
Since no one follows my build i have to ask questions here.
So i went to put the valve in. Its 2 parts the top which says 4040 on it and the bottom that says some other s hit do i need to replace these both into the old valve or just the top one. I ask this because the bottom one will not fit.
I'm going to rebuild the head, should I rebuild it with oem parts or aftermarket. For a n/a application with Nitrous.
Is there some secret way to get the brake booster off from the engine bay I took of the master cylinder. But the brake booster doesn't even budge. Any ideas?
Thanks I would like to finish the first and second problems today so that I can work on them if someone can help.
lilfed857
May 16, 2014 04:39 AM
aracka
Feb 22, 2007 11:23 AM
