FIRSTBORN FOR HELP WITH NO START V2.0
Old Jul 29, 2008 | 04:40 PM
kanada's Avatar
Default FIRSTBORN FOR HELP WITH NO START V2.0
test
Old Jul 29, 2008 | 04:42 PM
kanada's Avatar
Default RE: FIRSTBORN FOR HELP WITH NO START V2.0
i cant seem to post anything longer than a few sentences.....
Old Jul 29, 2008 | 04:43 PM
The forum is infected with an annoying computer virus. If you are having posting problems, screen capture your text generated in a word processor and then post the image.
Old Jul 30, 2008 | 04:27 PM
kanada's Avatar
well this gets even better....ruled out shorted injectors and the air idle control valve. started checking wiring looms trying to trace the yellow black wires. found an orange connector with a yellow black thats just under relay box that holds fuel pump relay and disconnected it to check for resistance...to see if it was going to ground. tried to start car without that connected and she started. plugged it back in to confirm that was blowing fuse and she still started. *now* i have 2 new codes......a code 41 and a code 65. i also have abs code 37. no more eld code. the speedo is also moving on its own...kinda like a tach. nothing is disconnected or any different than when it was not starting....beggining to lose my mind here.....any help? any chance bad alternator....im getting erratic voltages.....gonna have to replace alternator either way i guess...
David_S
Oct 24, 2013 10:06 AM
honvic
Oct 6, 2013 01:50 AM
pownstarz
Apr 19, 2010 12:30 PM
bmelloh
May 16, 2009 08:01 PM
Ronin Inc
EG Swaps
Jul 10, 2008 06:29 PM
