Flat Tire Repair
Old Oct 10, 2010 | 10:27 AM
EEPE52's Avatar
Default Flat Tire Repair
I need to repair, if possible, a tire. I read the owner's manual and it said do not use puncture inhibitors. If you do, then damage to the TMPS in the tire will result. So, my question is does this mean I can not have the hole in the tire plugged? If it can be plugged can an independent repair shop do it, or does Honda have special materials that must be used?
Old Oct 10, 2010 | 10:57 AM
That basically means don't use that canned fix-a-flat stuff or it'll mess up the tire pressure sensor. Independent shops usually use a plug to fix a hole.
dpula2
Oct 10, 2013 09:16 AM
kinosh
12
May 27, 2007 06:18 PM
ic892003
Jan 26, 2007 06:34 AM
roudan
May 23, 2006 10:14 AM
winka
Aug 10, 2005 08:10 PM
