Fluctuating idle??
Old May 21, 2011 | 02:50 PM
joshpawlicki's Avatar
Default Fluctuating idle??
Hi guys, I have a 98 civic ex with:A High flow cat, 2" performance muffler, headers, cold air intake, stage 2 clutch, short shift, and I moved the intake behind my passenger side tire. When my car is at idle, it moves up and down, also if I roll up the windows, it effects the idle. I have a 500 watt amp, and 12" subs, that are 500 watts. I have a 1 fared capacitor, and I don't think the system is effecting the idle. Even if my deck is off, it won't idle correctly. My original alternator started to fail, so I replaced it, and I had my battery tested, and that is fine too. Sometimes the car will idle right at 900(where its supposed to) and other times it won't. I cleaned my throttle body, and my idle control thing. I cannot figure out what would be causing this. Has anyone had the same issue?? Any ideas??
Old May 21, 2011 | 07:55 PM
conceptualpolymer's Avatar
JBaris
Nov 22, 2010 03:56 PM
kroopz
Mar 26, 2010 10:35 AM
Jeremy102579
Mar 17, 2010 07:18 AM
MR2nCivic
Mar 1, 2007 10:31 AM
plasticboob
May 19, 2006 02:01 AM
