fog light not working
so i got one of my fog light not working .. i thought it was my bad wiring .. cause it worked .. then later on it didnt .. so okay. . i redid the wire .. i solder the ends together instead of ghetto wiring it and i made it longer and i made the wiring's longer si there wont be much stress and then wehn i finished i turned it on it didnt work !! but hten i check the bulb and its not popped ~!! but i did find some water inside the fog lights probably from the rain or .. the fogs. ... .. wat should i do.. =(
You really shouldn't ghetto wire in the first place, take some time and get it done right. If you don't it usually never does. And try silicone around the back of the bulb and edges of the foglight. That will help keep the moisture out.
gunaa
Oct 22, 2009 11:36 AM
scottjreid
Oct 5, 2007 08:51 PM
chrisroug
Oct 2, 2006 11:36 AM
derekdunham
Nov 20, 2005 10:30 AM
derekdunham
Jul 25, 2005 10:39 AM
