Front brake calipers sticking
Old Sep 19, 2006 | 04:32 AM
eltakoduro's Avatar
Default RE: Front brake calipers sticking
ORIGINAL: deserthonda
ORIGINAL: Pete
Any way you can post pics? Ive done TONS of honda brakes and never come close to a problem like this.
i have seen it a few times
on 2 occasion it was a bad brake line , it was collapsed.. on more occasions it has been the master cylinder push rod misadjusted ( too long ) this happens a lot when people install non factory master cylinders..
If it was dragging before you replaced the calipers than the problem is not the brake pads nor the new calipers you installed........have you replaced the brake master recently ??
also as adviced try bleeding the brakes again
From what you said, it is probably the master cylinder then, since the brake lines were changed no 1000 miles ago.
I'll try and get a picture up as soon as possible.
Old Sep 19, 2006 | 07:11 PM
deserthonda's Avatar
also try sanding down the top edges of the pads ,,, see if that helps
Old Sep 24, 2006 | 02:04 PM
eltakoduro's Avatar
Default PICTURES Re: Front brake calipers sticking
they are new calipers, the rust is since the started to rain and the wheels were off and plus i live in miami so there is a LOT of humidity.
flipped the caliper up and you can see the piston sticking out
side view to show how much it is sticking out (a good 1/8th of an inch)
angle view with caliper piston sticking out
angle view with caliper piston pushed in
rotating view with caliper piston pushed in
side view to show how much difference there is when caliper piston is pushed in
comparison
thanks for all input!
Old Sep 24, 2006 | 04:00 PM
Pete's Avatar
Default RE: PICTURES Re: Front brake calipers sticking
The piston is supposed to be flush, not sticking out......im guessing you used a C clamp to push it back in? Is it not going back in all of the way?
Old Sep 24, 2006 | 10:07 PM
eltakoduro's Avatar
i had to have the bleed screw open and use both hands to push it back in, and even then it was kinda hard. any suggestions? any ideas?
Old Oct 18, 2006 | 11:22 AM
eltakoduro's Avatar
turns out the brake light switch had come a little loose (i have no idea how) and wasn't allowing the brake pedal to go back 1/8 of an inch.
guess that 1/8 of an inch mattered because once i tightened the switch in proper place, and allowed the brake pedal to return all the way back, brakes worked fine.
guess i got new calipers for no real reason... oh well :]
thanks everyone for your input!!
anibis
Apr 17, 2012 04:49 PM
chrisgsxr6
Nov 7, 2011 11:45 PM
dkyer420
Dec 13, 2010 05:41 PM
eltakoduro
Oct 18, 2006 11:20 AM
Stimpy
Sep 19, 2006 06:54 AM
