Fuel Gauge
Old Jun 11, 2011 | 08:31 PM
buckles474's Avatar
Default Fuel Gauge
i have a 99 ex coupe...
Is the fuel gauge supposed to lower to E when i turn my car off? My gauge constantly stays on the current level of gasoline regardless if the car is turned on or not.
Also i think my gauge is inaccurate. Sometimes when i have about an 8th (maybe a little more) of gas showing on the gauge, my car starts to choke when i try and start it. if there is just a little less then a quarter tank this shouldnt be an issue, so im starting to think that the fuel gauge is wrong. Any thoughts?
Old Jun 11, 2011 | 09:45 PM
stoochy's Avatar
It is normal for the gas gauge to stay at the current level when the car is turned off, my civic does the same. As for the "choking" on a low fuel start that is not uncommon. I found that if you turn on the ignition just so the fuel pump kicks in for a couple of seconds before starting on a low fuel, it will start no problem. Hope this helps.
Old Jun 12, 2011 | 11:36 AM
Jeremy102579's Avatar
my 2k ex stays at the level when car is off.
i normally dont let it get low on fuel, but when i have, it is harder to start.
Faramire
Sep 7, 2009 02:27 PM
siwel177
12
Jul 17, 2009 06:47 AM
TurboToyzz
Feb 16, 2007 12:46 AM
millertime17
Jun 26, 2005 09:38 PM
StifflersMom
Nov 28, 2004 05:51 PM
