Idle help, think I know the problem, but q's anyways
Old Jun 11, 2011 | 05:31 PM
zerojett's Avatar
Default Idle help, think I know the problem, but q's anyways
alrighty so the motor in question is the d15b2
starts up fine, idles alright at first
running at normal rpm, drops down to like 250-500 ish for a few seconds, goes back up for a little while, drops for a few seconds, goes back up, drops, etc...
i can't accelerate unless i give it half throttle, any more causes it to bog out like it's being suffocated
is this the eacv? would anything else cause this screwy idle?
Old Jun 11, 2011 | 06:06 PM
If it gets to operating temp, then drops to a low idle, but rises and falls, that's pretty much classic IACV. Clean it (super easy) and check it again. There's a DIY IACV cleaning in the DIY maintenance section.
Old Jun 11, 2011 | 06:53 PM
IACV won't cause that failure to accelerate. You should check the TPS. If you're saying that it is OK up to half throttle but it doesn't like wide open throttle, it could be weak sparks or starving for fuel (clogged filter).
Old Jun 12, 2011 | 11:50 AM
zerojett's Avatar
alright, so i'm gonna clean the iacv and then check out the fuel filter. it's funny though, low rpm WOT = no acceleration. if i shift a little later than i should, accelerates just fine. 5th gear at 80km WOT = no acceleration, 5th gear at 100km WOT = acceleration. as long as the RPM is higher than 2-2.5k (guessing, tachless at the moment), runs fine. it's like it suffocates at low rpm WOT.
knight101
16
Aug 6, 2010 08:43 PM
txedomask433
Jan 10, 2007 12:39 AM
torquemonster
Nov 9, 2006 12:22 AM
jbarham
Apr 4, 2006 03:05 AM
zagross
Oct 24, 2005 10:52 AM
